How to display same slide on both monitors?
I just updated to Windows 10 and now my slide show is displaying different slides - they used to display the same slide. Anyway I can display the same slide on both screens at the same time?
Ian
Administrator
Which app are you using for the slideshows? If it's the Windows 10 Photos app then I can't see a way, unless you temporarily right click the desktop, go to display settings and then change "multiple displays" to duplicate, rather than extend.
