RTL818x wireless connector
How do you enable the RTL818x that was disabled [not physically but by clicking on disable].
This is an internal RTL818x not external. It was disabled by mistake. I have not been able to find where to enable it again. Can you help?
You should be able to locate it in Device Manager and
Right click it and choose "enable".
You can also right click the start button and choose "Run" and
In the Run dialog box type
ncpa.cpl
Hit enter or click OK
And in that window right click the device and choose "enable
