cant open settings on win 10 pro flashes on the off was told to open task manager find
win explorer &click restart then restart pc this worked 2/3 times only any advice appreciated
Right click on settings in the start menu and go to more then click app settings then in the window that pops up scroll down and click reset.
If that does not work than open an administrative PowerShell and
type the following: sfc /scannow
once that finishes type the following: DISM.exe /online /Cleanup-image /Restorehealth
then restart your computer.
Open admin power shell andpaste the following into it: Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
Then try it once it finishes.
It reinstalls settings.
