SSD external USB3 drive keeps shutting down, power management is disabled
An external Toshiba 500gB SSD drive fitted to my recently rebuilt machine Win10 X64 keeps randomly shutting itself down. Model nmbr DTB305 purchased December 2017
I have disabled fast start and also sleep mode. It is connected to the main USB3 port on the IO plate.
Removing and replugging the usb connection wakes the drive up, no other action will.
Power management has been disabled on the root USB hub and anything else related to the drive.
I also tried updating USB drivers and for the SSD, they were all up to date anyway.
Sometimes it will shut down after an hour, sometimes it stays on much longer.
The only use for the drive is critical file backup using Syncback Pro with real-time fast saves enabled, and a scheduled weekly (Sunday)system image via WIN10 utility.
A Google search does not show a solution that I have not tried.
Help please, regards Jonathan
Maybe use a program like this one to keep the drive alive. I don't use it. Just a suggestion for you.
https://www.ghacks.net/2009/03/03/prevent-external-hard-drives-from-entering-sleep-mode/
Thanks Ram1220, for the moment I have disabled sleep mode (extended it to 6 hours before sleep) which has stopped the problem, although preferably I would want revert to allow sleep at 45 mins.
I looked at NoSleep utility, and its HD version. It was last maintained in 2009. Also found an alternative called KeepAliveHD which was last updated 2017. So, I am trying that.
I will note back after a few days trialling to say how it works on 64bit Win10.
Regards Jonathan
Check your power options, Advance option USB settings
Thanks for your reply Clintlgm.
As noted in my first post, disabling power management for the root usb hubs and anything else related to the drive was a solution I had tried which was ineffective.
But, thanks for you thoughts to help.
Regards Jonathan
Disabling "Allow the computer to turn of this device to save power" under the power management tab in device manager is a good first try, but...
You may also want to have a look at your advanced power management settings with respect to
USB settings
AND
PCI Express -> Link State Power Management
Make sure they are both off / disabled
USB settings
AND
Thank you Trouble, I have applied both those settings.
I will trial it a few days and note back if it resolves.
Regards Jonathan
