Touchscreen, audio, battery icon out after upgrade to Windows 10
After upgrading from windows 8.1 to Windows 10 touchscreen stopped working, audio isn't working, battery icon doesn't show on the taskbar, and that's the things that I've discovered till now. Solutions on the internet haven't worked, Asus doesn't have a driver update for it, Device Manager doesn't even show touchscreen.
I don't know if there is a solution for all this, or is it boding a bad experience and so I should roll back to Windows 8?
My computer is an Asus transformer t100.
HI Martel,
contact Asus and ask them what their plans for updates for your device are!. ;)
Hi Martel,
I have an older Asus MoBo and there are no drivers available for it!. It runs using Linux (any version) no problem, the soundcard won't work under Win 7 or Win 10!. :mad: The graphics card is also old (interegrated Intel GPU) and I cannot even run Google Earth on it!. :confused:
Hi Martel,
Well, okay, thank you. I guess that's it then. Thanks for all the time you dedicated to me :)
No problem Martel, let us know if you need any more help with anything!. :)
