What is the difference between watermarking an image and adding a shadow effect to it?
Watermark and shadow effects are different from each other. A watermark shows the implementation of the logo of the business and the signature of names in semi-transparency but the other-side shadow gives the effect of the graphic in design not proper visibility in the PDF document. Keeping your question in mind, I consider it appropriate to give some suggestions for using the advanced automated specialization features of Softaken PDF Champ software. Users can easily select their locking unlocking merging splitting add watermarks and convert PDFS into image format such as JPG, PNG, or BMP, features to proceed with their tasks. You use his main key feature to add a watermark on a single page or multiple PDFs with a few clicks.
The best thing is that this tool allows you to upload locked PDFs but the utility wants the correct password before proceeding with their task. The application permits users to customize their PDFs. The application assures users not to do any annotation while proceeding with their task. The interface of a utility is easy to use and runs on all the latest Windows OS.
