wireless projection
if my D-link 655 wireless projects a signal to Kindle and laptop why won't it project to big screen tv. Dell 755 optiplex upgraded to 10. no miracast support. I have an intel widi hdmi dongle inserted in tv hdmi port.
I am getting confused as to connecting wirelessly these days. Intel seems to say they no longer support WiDi and I have seen some folks say the WiDi software has been removed from their systems.
When you select Project from the notifications panel, can you click on the Connect to a wireless display and see the Intel device?
all it says is this pc doesn't support miracast and can't project
I just checked mine and it sees the Netgear wireless display. I was always under the impression the wireless display talked directly to your system and not through a router.
If that were to be the case perhaps the wireless adapter ismimporant and which capabilities it has. I have been WiDi to work in the past but never Miracast. Now I am not sure which wireless version we are using or what the Miracast requirements are, I did know the WiDi requirements.
Edit: I found this site which lists equipment, if it helps..
http://www.wi-fi.org/discover-wi-fi/wi-fi-certified-miracast
I believe miracast is not supported anymore.my old computer says it is not capable of projecting. no wireless capability. I just wonder why if the wireless router transmits to kindle and another lap top why it wouldn't work on tv. maybe I'm spinning my wheels and need a new pc just so i can stream from the internet.
I just checked my ASUS system with NVIDIA video and onboard wireless. It found the Netgear device (PTV3000) which is both WiDi and Miiracast capable.
