100% disk usage please help
2 days ago i downloaded a new game Playerunknow's battleground and noticed i was lagging really bad. I opened my task manager and my disk usage was at 100%. I closed everything and noticed my pc was doing things slow. My disk usage stays at 100% now and I do not know what to do. I ran some test and disabled some services that an article online suggested that helped others but does not seem to work for me. I was wondering if it is a good idea to uninstall all my drivers and download new ones. Please help me i really dont know what to do
I have included any screenshots that may be helpful
This is my task manager at the moment. It changes a lot sometimes. system is consuming more then windows search, sometimes norton, sometimes Microsoft compatibility telemetry.
Hi antmann,
Taking a look at your task image it seems its your Zip Console consuming a large resource from CPU.
Do you really need that third party application? Windows has its own compressed file management built into the OS.
Also, if you are using a SSD with the game running from that then it would be worth checking out this known bug issue Microsoft posted about with a solution some time ago now:
https://support.microsoft.com/en-us...h-message-signaled-interrupt-msi-mode-enabled
This may or may not be relevant in your case; but worth reading just in case your computer's specs align to the article.
Hi antmann,
This usually changes now it is not the 7-zip file it is now my system doing most of the consumption.
http://imgur.com/a/8LY5v
http://imgur.com/a/JetVG
I would suggest you open the resource monitor to check the usage. When you see something using resources, put a check mark in the box so it will filter for that process in the lower panels.
The utility will also show you what is being done.
Microsoft compatibility telemetry disk usage make the system slow and annoying. It actually a service in Windows 10 which have information about the technical data that how the Windows devices and its related software is working. I like to come here to get the solution of this problem.
