SOLVED Driver for best driver for nvidia geforce gtx 1050 ti
Hi. I'm having so much trouble finding a driver for best driver for nvidia geforce gtx 1050 ti. Nothing seems to work. I'm not wanting anything tor gaming.
What brand of gtx 1050 ti is it (msi, evga, etc)? It's odd that the latest driver wouldn't work for it. Also for general use, the driver provided by windows update should be sufficient.
If it's a laptop then the OEM supplied driver will be your best choice. If it's a desktop then Windows Update as mentioned above.
