Self built PC, poor optimisation?
Hi, i just ran the userbench mark app (https://www.userbenchmark.com/). is this a good indication of pc performance? is there something better?
It gave me the following results, some are quite disappointing. For example the CPU and the RAM seem to be under performing.
Any advice?
UserBenchmarks: Game 95%, Desk 88%, Work 97%
CPU: AMD Ryzen 7 3700X - 80.7%
GPU: Nvidia RTX 2080 - 116.6%
SSD: Adata XPG SX8200 Pro NVMe PCIe M.2 1TB - 251.6%
SSD: Samsung 970 Evo NVMe PCIe M.2 1TB - 278.2%
SSD: Samsung 850 Evo 500GB - 102.9%
HDD: WD Red 8TB (2017) - 101.9%
HDD: Toshiba HDWF180 8TB - 95.8%
HDD: WD WD60EZAZ-00ZGHB0 6TB - 82.6%
RAM: Corsair CMW16GX4M2D3600C18 2x8GB - 63.5%
MBD: MSI MAG X570 TOMAHAWK WIFI (MS-7C84)
For your RAM, do you have it set to run at 3600mhz? For you CPU, have you tried upping or lowering the voltage?
I just did the same test and I have much older hardware and I have a 25% CPU background usage. That's due to all my RGB accessories...ie keybard/mouse, case fans, mouse mat.
Also try setting your BIOS/UEFI to default as @bassfisher6522 points out that under/overvolting power to the CPU and wrong RAM speed settings can really mess up a computer!. :)
