I use win 10 V 2004 and as of late, I have noticed that both screen saver and power saver will not function unless
I remove the Logitech 3D extreme pro joystick.
As a work around, I've discovered that if I disable the device driver and then re enable it, the screen saver and power
saver will work. This wasn't an issue a few Win 10 upgrades back.
I'd like to make a batch file that would disable then re-enable the USB port for my joystick.
Anyone else out there have this issue? If so, what was the fix?
I don't know what the script would read for the batch file for the workaround but it would have to disable the
JS USB port and the enable it.
