Problem with installation
When i try install windows 10, installation process is freezes in this moment:
Did you happen to use the GTX.exe icon in the bottom right corner of your screen near the clock to check your system for compatibility issue? "Check PC"?
I have precisely the same problem, both on a desktop computer and a laptop. I want to create a clean install of Windows 10 alongside Windows 7.
Continuing from my previous post. Using the image I used before I made a bootable USB stick. Starting from this device the installation proceeded flawlessly. Thus my image was OK but the DVD I burned from it did not work.
