- Jul 12, 2016
is there a way to avoid not by me selected redirecting in edge, eg to not wanted porno pages.
			where do i find this add blocker list?Add the unwanted sites on your add blocker list.
the problem was in EDGE. I just installed uBlock and it solved my problem.I use uBlock with Fire Fox. It does a great job with most, if not all browsers.
What browser are you running.
https://www.ublock.org/
There is a free app in the Store for Edge browsers called UBlock Origin. It seems to have a popular rating and is capable of running a background anti redirection algorithm.
I've not personally added any extensions so I cannot give a first hand opinion, but perhaps someone else in our forum uses it as the original app was for Google Chrome, and now it also supports Edge.
