There is a wealth of knowledge here foal, I sure your question will be answered, if it hasn't already been done. If you would like research this subject futher, you can also Google your question (i find this also helps also, sometimes).
https://www.google.com/search?q=How+to+restore+Windows+10&ie=utf-8&oe=utf-8
I see from Settings then click Update and Security, you have "Back up using File history". The only thing to my knowledge would be to use a USB flash and back up Music, Pictures ,and downloads from file explorer.If you fear losing anything. I've done it before (it was easy, just click and drag).
I sorry about the earlier confusion, I didn't understand what you were saying. Again this may not be your answer. There are sharper mind here than mine.
I'm just trying to help: Good Luck
