Build 16241 for PC
Looks like this might be available sometime within the next hour.
SOURCE: https://twitter.com/donasarkar/status/885539491536134145
Downloading now (high noon) my time
https://blogs.windows.com/windowsex...41-pc-build-15230-mobile/#dpDbuWAsEQud4eld.97
I may give this release a pass as I see there are still IMAP issues yet to be resolved.
Then again, lol - temptation may get the better of me :)
A bit over two hours from start to finish, some of which is probably attributable to ancient hardware.
Some rounding was employed but everything is reasonably accurate.
Now I'll use the ISO that I created from this install to upgrade my other installation which will likely take about 30 minutes max.
Same for me and it is not usable. I am done with this. Thanks Trouble.
Not too far off my estimate.
From clicking setup.exe from the mounted ISO to a useable desktop.
Surprisingly enough...... Yes it is.
Funny. The previous build did not want to install and this one only started cause I updated Defender prior to that but it went through without problems....
I did a clean install of build 16241 and my PC will not wake up from sleep without a restart.:cool:
Has anyone checked their Update history for this build.
I seem to have 3 failed attempts to install something called
"Microsoft Advertising SDK for XAML"
On both my installations (physical machine and VM)
this comes up on my Insider machine:
might be a good thing??? less ads ???
Same thing I'm seeing.
Not a clue what it means or if there's a downside to it failing or not.
Guess we'll see when the next build drops.
Thanks for checking.
I am not on the current rs_Prerelease, but that failed install rings a bell.
Did not the exact same package cause issues in the 14393 builds. If memory serves me right it had something to do with long file paths, and Microsoft provided a tool and explanation how to manually install that using the tool to avoid the long file path name issue.
I tend to book mark Microsoft solutions, so I'll see whether or not I can unearth it for you.
Thanks Timothy, much appreciated.
It's looking like tomorrow for the next build so hopefully that particular update error won't cause problems when attempting to update the OS to a new build.
With the new build on the immediate horizon (within the hour) it seems that I've raised the failed count on the earlier issue and have now added something called "Microsoft Engagement Framework" which seems to have failed twice now.
I also seem to get to enjoy this from time to time when using Internet Explorer.
While definitely funny (as in "humorous). Not helpful nor particular informative.
SOLVED Preview Build 18329 8
SOLVED Preview Build 18323 13
Public Build Releases 9
SOLVED Windows 10 build 18298 3
