Help problems with pc to tv
I have what might be an old flat screen monitor but to me it's the newest type I've ever had. I wanted to be able to watch Youtube on tv in the kitchen tv and learned that you can go DVI to HDMI to the tv and did get that to work with the original monitor still plugged into whatever it is. But it changed the resolution or something and all the icons got small and it said they became small icons instead of medium which is how they had been and how I want them. Doing some of the things people suggest like on the desk top right click, personalize, display, windows key + P, duplicate finally did work and that's what got so I could see the computer on the tv and still also on the original monitor though now the icons had all been made small. Trying to get over that problem I went the route suggested here:
where some people are actually able to see both display devices as 1 and 2 but of course things don't go that way for me and I could only see one thing I believe it may have represented itself as 112. Whatever it called itself there was only the one item show so somehow I clicked on an option to show only the monitor and the monitor immedietly went black and said it had no signal. The tv still had a signal though but I couldn't work with that yet because I have a USB mouse instead of wireless. When I unplug the tv the monitor suddenly has a signal and works again. I plan to bring home a wireless USB mouse and after disabling the monitor by plugging the tv back in try to work out some way of getting back to where I was for a short while when both the monitor and tv worked and were a duplicate. Can anyone suggest the best way to do that and if it's possible to somehow see both displays as different individuals and maybe even get the original monitor to show medium icons and let the tv show whatever icons it wants to....I just want to watch Youtube sometimes while I'm getting dinner ready.
Thank you for any help!
David
ME, USA
Hi David,
is this a laptop or normal PC we are talking about here?. If it is a laptop, try pressing the FN key and something like F8 (on my laptop) which brings up a screen menu on the right!.
There are several vids on YT!. :)
Hi David,
It's a normal PC. I've seen several things that explain how to do this but mine doesn't seem to work quite the same. Like where it's supposed to show a number one and number two display mine only shows one option even when both are connected and working. That's why I tried selecting just the monitor setting instead of duplicate and after doing that the monitor immediately went black and said No signal Input. So I disconnected the tv cable and it came back and when I plug it back in it goes black again... I haven't found anything on Youtube about that yet.
Not really sure, you can try resetting your monitor setting on the PC without the TV connected, then start again!. I assume you have the TV remote, have you selected the correct input source assuming you are connecting via HDMI/VGA?. :)
I have successfully cast what is on my 5 year old laptop (Dell Inspiron with win10 pro) to my 10 year old Samsung 36" by using the Bluetooth and Project features on the laptop. Works great and easy to use.
David
ME, USA
Purchase chrome cast. It lets all devices to cast to your tv. Also most
Dell systems have an html port. Both my desktop and laptop have one. Chromecast cost 35 dollars.
