- Feb 28, 2017
Win10. Edge Prints blank page. At first I thought I had a clogged nozzle and used utility to clean. No luck. Then reloaded driver and rebooted. No luck. Printing a test page worked fine. Printing a document works.
Finally, I noticed that the screen you use to control Edge printing showed a blank page, (see right side below) Which is what it prints... Nothing! This is the screen that appears when you right click for printing. When I used IE a different printing screen showed and worked fine. Both Edge and Dogpile have this printing bug. It worked fine a couple days ago? Any idea what is going on?
